ok im having some big problems first im installing the motor in my 94 JDM del sol now the first problem im having is that i bought two 93 integ axles with the accord mid shaft and the integ driver side axle will not go in all of the way i was wondering if the two axles were shorter then one another. the second problem is the trans when it was out sitting on the ground would shift into all five gears and reverse but now it will only shift into 4th and that's it can some one help me out please
if it would shift into all gear before but only 4th now i suspect the problem is in the routing of the shift cables how tight is the kink in the cables? perhaps they're binding in their housing
i fixed the trans problem but now i still having a problem with the cv axles not going all of the way in the trans on the passanger side and the other cv axle will not go all of the way into the mid shaft
the integ axels work most of the time but .. you might have bad teeth.. or some thing blocking .. maybe lube it up a little.. heh some thing like that.. i didnt have problems with my friends hatch
