Okay guys lets wrap this up, coming from Honda Motor Company, tech,
The Type S is worth it reasons why...
The H22A Type S 220 HP, 163lbs @7200 RPM
(1) The Type S boasts an impressive 100hp/liter engine, producing 220ps from
2.2 liters (2,156cc) utilizing its VTEC technology.
(2) It also comes with the new Prelude's signature ATTS (Active Torque Transfer System) with a new LSD five speed transmission, and the Type S is treated to an active-control ABS that improves braking through turns.
(3) With its smooth torque curve, lower intake resistance, higher compression, and secondary balancers on the engine...its a materpiece.
(4)Type S engine, like the Type R engine, receives a port-&-polish job from Honda.
Honda created a new piston head that increased the compression ratio to 11.0. By doing so, the burn-off response increased, helping heat dissipation, as well as improving torque throughout the power band.
(5) As far as cams go the valve lift on the intake reaches 12.2mm, while the exhaust end reaches 11.2mm. As far as production engines go, these are really high numbers.
(6) Utilizing what Honda calls "dynamic chambers." The throttle body was also bored out from 60mm to 62mm. Even the material used in the inlet manifold was changed to a more fine, granular one in order to make it more smooth. The valve seat was re-adjusted from 60 to 45 degrees. Finally, the cylinder head and intake port was treated to a manual port-&-polish job by Honda technicians.
(7)The exhaust manifold, while retaining its outer diameter, had its opening size increased. The dual-pipe design to follow was made truly cylindrical, (as opposed to oval) and the wall lining was made to 15mm -- decreasing exhaust interference. The catalytic converter was also increased in size, and the exhaust piping increased from 50.8mm to 57mm. The silencer efficiency was increased from 97 liters/second to 113 liters/second. This completes the improvements made on the air flow efficiency of the Prelude Type S.
http://www.accordwagonclub.com/images/a26big.gif
http://www.accordwagonclub.com/images/28big.jpg
http://www.accordwagonclub.com/images/51big.jpg
http://www.accordwagonclub.com/images/a25big.gif
