H22 Wire vs Shifter..
Discussion in 'HYBRID -> EG-EK / DC' started by FastRCars, Jun 28, 2005.
  1. FastRCars
    FastRCars Member
    So..as topic says , what "shifter" can i use to get this prop working?
    Is there any big diffrents between all this H22 ludes from 92-01 ?
    I got this H22 JDM lude engine with a 5speed LSD gearbox...most of the parts i got avaible is EDM modells
    Will the shifter from a EDM Honda Prelude -98 2D Coupé 2,2i VTi 5gear work??
  2. pissedoffsol
  3. FastRCars
    FastRCars Member
    Well it didnt say so much about how solveing the shiflinkage problem , i need to know which car i can take the whole "shift mechanism" , i got the shift linkage intact boltet to the engine so..just the "inside" car stuffs..
    // J
    EDIT:
    I got this "shifter" from a junk yard nearby , its from a Prelude 2,3 Coupe
    I hope it will work..look the same though.. :huh:
  4. pissedoffsol
    looks good to me. should work
  5. FastRCars
    FastRCars Member
    Yeah..seems alright , will look further to that when the engine is in its place. :rotflmao:
  6. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    that is the linkage for it i seen it on other threads, i still want to know how that works getting it in to gear and all i have not seen it first hand
  7. FastRCars
    FastRCars Member
    Jupp should work..:) , ill let u know 100% if i make it
  8. FastRCars
    FastRCars Member
    Well now the shifter is there and it seems 100% ok so far , the gears slides in perfectly
    I cutted out a square hole and looked so i got enough clearance for the shifter , then we cutted a smaller hole about 2 inch x 2 inch 18inches away from the center of the shift mechanism , it went out realy great!
    So..now im a step closer..:)
