h22 with h23 tranny
Discussion in 'Prelude' started by quiefanator1, Oct 26, 2006.
  1. quiefanator1
    quiefanator1 New Member
    im about to get an h22 put in my 94 prelude and i no i can just bolt up my old h23 tranny to save me some money. but will it hurt the engine performance? doesnt it have different gear ratios?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    it does but not enough to worrie about. its not gona hurt the motor any
  3. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    are you serious? yes the gear ratios are quite different. it will hurt you pretty good in acceleration and espically in your quarter mile time.
    example. i raced a 93 lude with h22 and h23 tranny..and ill just say i put many many lengths on him.
    so in sum yes there is a noticable difference between the two tranny's but if you are on a tight wallet then the h23 tranny will still make a very noticable difference from the f22.
  4. AHHVTEC
    Alabama
    well ive only compared the h22 tranny to a accord tranny and there wasent that much diffrents i just assumed the h23 would be about the same
  5. quiefanator1
  6. iamcgr
    iamcgr New Member
    San Diego
    I'm looking to do a auto to manual transmission swap to my 92 h23a prelude. Would a h23a do well using a h22a trans? I'm looking to boost it soon after.
  7. powerdriverh22
    spfld, mo
    it would work just fine but the h22 tranny has shorter gears that are better for all motor. if you are going to boost it just stick to the h23 tranny. it will serve you better.
  8. daveyboycd6
    daveyboycd6 New Member
    is it possible to put 5th gear from h23(M2S4) into the m2a4 trans for econo highway drive?
