Hi.
I am having a problem with my clutch and shifting. i replaced my clutch and bleed the system a couple of times and everytime i drive it for a while my transmission seems to get harder to shift, eventually not letting me shift at all while the car is on. i bleed the system again and off and running for a while again. i have checked for leaks but cannot find any. i replaced the master and slave cylinders about 2 months ago. i have been searching groups for answers and have found some suggestions below.
there is an adjustable nut on the master cylinder that i have seen someone say in a thread can help if i adjust it. which way is the correct way to adjust it? towards end of rod or away?
i have also heard that the master cylinder can get air trapped in at that must be released before installation and can not be bleed unless it is removed. is this true?
the clutch was installed with a new pressure plate, release bearing and flywheel, aligned correctecly and bolts tourqed in correct order.
the last clutch and this clutch catch kinda of high, i am thinking it has to do something with the adjustment of the master cylinder. any suggestions greatly appreciated.
please help
please help
