h22a ecu qustion
TomZZ30
I have a p14 ecu which is the single overhead cam with no vtec right? I was wondering if , I could run the p14 ecu with a vtec controller? would the h22a run perfect?
okay thanks guys on a search for a p13 now lol
if you plan on doing anything big to the motor later (turbo, new piston or cam) id start looking for a socketed p28 or p72 that you can have someone make a base map for. the p13's only upgrade path is neptune.
cause i fail :p
maybe its the swap from hell?
okay then i could uses that ecu just to see if it starts another qustion , would an F series tranny work on an H series?
Yes, the F-series tranny will work...well, assuming that it's not an S2000 tranny. Any FWD F-series tranny will work...
