H22a from civic to integra
Discussion in 'HYBRID -> EG-EK / DC' started by The Godfather, Mar 16, 2012.
  1. The Godfather
    The Godfather New Member
    Ok so I have a eg civic hatch with a h22a and prelude gearbox to match... Civic has Hasport engine mounts for h22a
    I'm sorta over the civic shape and would like to swap all the stuff from my civic into a dc2 integra!
    Will everything be a straight swap over?
    Can I use the shocks and springs from civic to Integra?
    Any help would be greatly appreciated :)
    Thanks
  2. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    It should be a straight swap.
    I can't think of anything off the top of my head.
  3. primeredseol
    primeredseol New Member
    you can swap it all over to a DC2, but as was done in your civic, you will have to cut the center tunnel of your car to mount the prelude shifter assembly and route the shifter cables.
  4. The Godfather
    is the cutting of the tunnel straight forward? is there a template anywhere? i never had to cut the tunnel out as i bought the civic with it all done...
  5. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    he means if your tunnel is not cut already you need to set your shifter and cables on top of the tunnel and mark your oval cut out at base of fire wall and tunnel meet and cut your shifter hole wider to fit shifter assembly,if this helps give me some rep,good luck,lol... your cables will set on top of your tunnel and go through the hole at fire walland make sure you put a rubber gromet on edges of hole to reduce cable tearing or put protective foam around cables...
  6. primeredseol
    take the center console out of your integra, look at how the cables a routed and shifter was installed. Copy then paste into the civic chassis.
  7. 98EkSi
    98EkSi New Member
    Only he will want to do it the other way around as he wants to put the H22 into a Teg from his Civic. Yep it will be a straight swap out to the Teg chassis.
  8. primeredseol
    ooops. lol
