H22a Getting It Turbocharged
Discussion in 'Forced Induction' started by 300hph22civic, Feb 16, 2003.
  1. 300hph22civic
    300hph22civic Member
    Hey guys , I know all turbos are different, but I was thinking about turbocharging my H22A,
    and since the compression is already 10:1 I was wondering , would around 6-9 psi be too much for
    a daily driver, or will that jack the compression up to high, and possibly kill my engine, please advise
    Thanks guys&gals
  2. pissedoffsol
    anything untuned will blow up. its just a matter of time. might last 2 weeks, might last 2 years.
  3. mwasnp
    mwasnp Senior Member
    Hopkins, MN
    If you tune your motor correctly you could use 8 lbs of boost from a decent size turbo. I would recommend a t3/t04e. I would definately recommend hondata or a similar EMS.
  4. 300hph22civic
    So would 6 psi be ok for a daily driven H22a with stock internals
  5. civicSiR1
    civicSiR1 Senior Member
    tuning up your motor to handle turbo modifications is a must if you want some good power, but if your just going good enough for a daily driver, I would go with Trust or HKS. but still i would build it up to at least mid built. throw in about 6 to 8 lbs. a hondata ecu will help you too. runing on stock internals is a risk, but it'll handle, at least not for long.
  6. turborex13
    turborex13 Member
    if u have turbo questions go to homemadeturbo.com that is the best turbo information source around.
  7. BigJ
