have many h22a and h22a4 parts for sale
h22a COLSED DECK! block with crankshaft installed i used, new ACL main bearings and thrust washers tolerances are perfect - $700
h22a eagle esp H beam connecting rods with arp 2000's NEW in box ( cannot be used with type s pistons ) -$300
h22a acl rod bearings NEW in box - $80
h22a/a4 oil pump NEW in box - $160
h22a stamped steel oil pan - $25
h22a4 open deck block no crank, but have main caps and girdle/oil pan - $250
h22a4 head with stock cams + cam gears - $300
h22a4 black valve cover - $50
h22a4 intake manifold - $150
h22a4 aluminum oil pan - $50
I have many other various parts 2 sets of stock pistons one for a4 and one for the a, stock rods rear main covers a set of gaskets and an a4 vtec solenoid, a deal could be worked out for all of the parts. SERIOUS REPLIES ONLY, this is what i have so don't waste my time if you're not going to buy it. trades are possible
local pick up on larger items, smaller could be shipped.
