H22A H2B B16A Tranny
Z6CRX
übber ɐɾuıu etarip
QSD H2B Kit $850 - SOLD
8lb Aluminum Flywheel & Exidy Clutch (cable type) $125 - SOLD
Explicitspeed Alternator Relocator Kit with Alternator (Believe it was a D series) $85 - SOLD
H22A Longblock, Could use a rebuild on the head. Includes Intake and Exhaust, no coil pack $425 - SOLD
1G JDM B16A Transmission $300 - SOLD
Both axles and Intermediate shaft for B series swaps $65 - SOLD
Throttle Body (H22A) $20 - SOLD
Intake Manifold (H22A) $15 - SOLD
Generic B Series Mounts $80 - SOLD
LoCash OBD0-OBD1 Conversion Harness with Distributor harness Sold to acura1
Stock CRX Crossmember cleared to fit H2B (with kit or offer) - SOLD
1,200 Firm Prefer Pickup
, I can help you find a place to pick it up and ship it, GSR ECU will cost extra
Pretty much everything needed minus shift linkage and a new coil pack for the distributor is here. (but I have the parts to convert it to an internal so all that would really be needed is shift linkage)
Theres probably a few things that I'm missing but I have some other parts for other applications if need be.applications if need be. It will be likely you will have to modify the header to fit your application.
Selling because I don't have the room for project cars and I would like to get a bike.
More pics and information is sitting below.
I have people continuing offering to buy the whole setup, I may consider selling with 2 parts but it would be much easier to sell so I don't have to take it all apart. (I''m not selling the bracket by itself and if you ask I'm assuming you can't read so me telling you a price wont help 1,200 with tranny 1,400 with engine)
LOBALLERS NOT WELCOME
this is already a deal, and as low as this will go, try buying it from someone else for less for all this.
Some pics of the engine with the plate updated for now. 2-4-08
Bump!:huh:
I will even just sell the H2B with or without engine I can negotiate a fair cost.
This thing will fit into other cars too. I hear H2b's can fit into EK's with no hood modification.
how much just for the h2b..... it will also work on f2b too... Thats the kit and the b16 tranny right ?
Shipped to 23236
Lets give it till this weekend see if i cant sell it as a whole.
But in the meantime I would like to get some pics up if there are some serious buyers so they are aware of exactly whet they are buying.
I have been told it will work with F series motors. but i believe you have to notch the back of the block just like the H22. And I am unsure if the alternator re-locater kit will help in this application.
Its basically converting your engine like you would have a b series swap.
Easier to put it. Let me get back to you on selling the individual parts.
I'm just listing this back up for roughly what i originally paid for it.
Probably can expect the cost of it to at least drop by the price of an H22 if that helps. (I'd say by about 800) but it also depends on what else you want with it.
Just PM me on the parts you're looking for. Ill get your figured out first and then post up here shortly after on the figures and pics of everything else.
Thanks for the interest ^_^
Bump!
I have heard of people modifying the kit to fit a D. all that would be done is drill new holes in the plate to get the spacers.
Same idea as mating a Chevy engine to a Ford transmission. Why would someone want to do that?
I will have pics tomorrow maybe tonight since my lazy ass got out the camera.
B16A Cable Transmission
somewhere between 70-90k miles estimated most likely less. I was told no grinds but I never took it up in the short time I had it so cannot say if it had grinds or not. No problem shifting through all gears about to 4500.
H2b Kit
Clutch, Lightweight Flywheel, Pressure plate.
H2b Parts from QSD H2B
Hoses meant for swap into Civic/CRX chassis
Alternator relocator kit
H22A Engine Longblock
Code (front 1001080, back 1913074) I will get compression numbers if you would like but there is a cheap head gasket and blowby on an exhaust valve on cylinder number 4 that disappeared once the engine was warm last time i checked. (the valve cover is black, but not pictured) Has a brand new distributor but needs an external coil pack. I have the parts to convert to an internal if you would like.
90-93 integra axles.
Spindle not included. the once just needs a new clip on the boot.
Top left to OBD1 B16A XSI ECU (forgot to get the code will have it up soon) (JDM)
OBD1 H22A ECU P13 (JDM) (prefer to go with engine)
OBD1 B18C1 ECU P72 (USDM) yes thats a windwos xp home license sticker on it (does not come with it)
OBD1 B18A1 ECU (PR3 I think) USDM
LoCash OBD0-OBD1 Harness $90 + shipping
Honadta S200 Unit, Box only (As is, havent used it, came with my crx, it wasnt hooked up) If you buy the H2b kit with engine and transmission I'll throw this in, with a few more goodies.
and how many miles on the transmission ?
does it need a rebuild ??
I'm not sure on how much they go for, but throw an offer out.
Bump!..
bowling is hazardous to your health when going for more than 5 hours.
bump! got 3 prospects.
