h22a head on f22b1 block
Discussion in 'HYBRID -> BA-BB /CA-CD' started by 45455, Oct 1, 2003.
  1. 45455
    45455 Junior Member
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    Um, I don't think so. Even if it were possible, and you went to hella expense to make it work, your compression would still be low. Not feasible, it would be cheaper and easier to install an H22 complete.
  3. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    The search button is your friend.
    As tab said, it's not even close to being worth it.
  4. jdmlude92
    jdmlude92 Member
    please end yourself. :spin:
  5. coco4pr3z
    coco4pr3z not to up on these hondas
    thank you.....i was thinkin about askin the same question and now relaize that i should jus stop being lazy and drop the entire motor in....wat about my stock 5 speed tranny of the f22b1? should i stick with that or just get a 5 spd off an h22a?
  6. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    its very possible. there are several write ups on this. here is one of them. it is feasible. it wouldnt cost 2000 to have done. if you were going for boost then its not a bad option. however because you compression will be so low its not going to make for a good n/a motor with out the proper equipment.
    Honda-Tech.com: F22b2 block+H22a1 head, F22 VTEC, F22B/VTEC
  7. Finest
    Finest New Member
    What you can do to increase compression is deck the block, or bore out the cylinders to the service limit and go with oversized OEM pistons. Either way, it'll be a nice motor to throw some boost ontop of.
    But then again, ~8:1 CR isn't all that bad considering my 90 AWD DSM has 7.8:1 CR. :D
    I'll be attempting this hybrid since I snapped a crank in my a4. If the block isn't salvageable, I have a spare F22 to tear down for parts. ^_^
  8. powerdriverh22
    spfld, mo
    they only problem with decking the block is that you are taking material away that you can never get back. id rather see pistons in there.
  9. daveyboycd6
    daveyboycd6 New Member
    there was a civic on you tube with a f22 block h22 head and it was turbod boosting 15 psi 680 whp it claimed..
  10. 89h22hatch
    89h22hatch Senior Member
    I have an f22 block with an H23a1 head non-vtec, and it isn't much trouble at all. Lot of torque and low end power. I'm having the head rebuilt right now though so i can get higher RPM's.
