h22a help
tlmg21700
i have another problem i finally got my h22a running in my 94 accord and now the cr barely wants to idle it sounds like the car is has a slight skip in it but all of the cylinders are firing and i have compression if i give it gas it sounds like it is rotary my timing is good an all of my spark plugs are black let me know if anyone had these problems thanks
what does this mean?
Were they new spark plugs when you did the swap? Are you getting any codes?
:spin: :spin: :spin: :spin: they are new spark plugs and the codes are because i didn't hook up the wires to the ecu yet cause there is a,b,c and every thing i look up for the ecu i says a,b,d i don't know if the c and the d i the same allright thanks :spin: :spin: :spin: :spin:
you need to completely hook up all the wires and then go from there. see what codes your gettin from the 2 pin by connecting the 2 pins by the ecu.
