Ok, I have H22A 92-96 OBD1. i got no sparks on all for of my spark plugs. I took the dist. cap off to check the ICM, i found the ICM and tested that. This could be the problem. While going down the list, it says to check the IGNITION COIL. Where is this coil located? It says that it has a 4 pin plug, the only thing i can find INSIDE the dist. cap is a 2 wire plug w/ a little spring on it. Is this it? Or am I blind and cannot find the Ign. coil? Help me out.. What do you think that's causing it not to have spark on all 4 plugs?
