h22a in eg swap help?
Discussion in 'HYBRID -> EG-EK / DC' started by hondavet1218, May 23, 2009.
  1. hondavet1218
    hondavet1218 New Member
    Yakima Washington
    im in the process of swapping a h22a in my brothers eg ive got everything for the swap now ive done mostly just b series swap so this is new for me ive done alot of researching for this swap and i think i can pull it off the only thing i cant find info on is what modifications do i have to do the the rear mount tranny bracket to bolt to the new swap. it had the stock d15 do i use that same mount bracket? any answers would be greatly appreciated thanks fellow honda swappers
  2. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    no , dont use stock mount you want to use a bracket off a 94-97 accord rear bracket this bracket will work,it took me awhile to , got info from swap shopracing.com where i got my mounts from!!,anymore questions feel free to pm me .....
  3. hondavet1218
    Yakima Washington
    kool i hope i can find one at one of theses shitty wrecking yards thanks much for the info i really appreciate it
  4. toub18c
    toub18c New Member
    millwaukee
  5. xplicitcivic94
    xplicitcivic94 New Member
    will i be able to use 94-97 accord rear bracket on my 94 dx?
  6. 97h22dxcoupe
    Coffeyville, ks.
  7. 97h22dxcoupe
    Coffeyville, ks.
    ok, my mistake on bracket,use the 92-95 m/t bracket off a prelude, remember there is two kinds 92-95 and 97-01 has a slightly larger bracket and 92 - 95 is shorter use this one with aftermarket inovative mounts , if this helps you out rep me up..lol
  8. 97h22dxcoupe
    Coffeyville, ks.
    you need the b series mount....
  9. xplicitcivic94
    is that for the the dx?
  10. 97h22dxcoupe
    Coffeyville, ks.
    no they are from the si ,b16a mounts
  11. xplicitcivic94
    what mount can i used with my swap? 94 dx h22 swap?
  12. daloco1
    daloco1 New Member
    williamsburg, va
    innovative sells a nice set for h22 in a eg.
  13. 97h22dxcoupe
    Coffeyville, ks.
    97h22dxcoupe
    yeah,or you can go to swapshopracing.com- thats where i went they got some good mounts for this swap...
