h22a into 88 lude
kedge
after any help in regarding this swap
web pages, photo's etc
basicly have done the transplant now doing the wiring and im sort of lost
can i get the engine to run first without the computer conected then conect the computer later
have swaped a 1992 h22a into a 88 lude used harness and computer from the 92 lude and striped it down to the computer main harness all i need to do is add power to the computer i think it's 3 wires correct me if im wrong, change the dissy from external to internal and hook the starter up and fuel and it should go.
im so close but i just need a little help from you guys to get this project finished
any help would be greatfull it will be the only car like it in nz
cheers
kedge
you NEED to use the comp for the motor to run at all. How else would the injectors know how long/short to open, or to open at all? just take your time..
need any specific questions answrd?
will yes, do i need to run some extra wires from the computer to the engine sensors
and in the chilton manual were is the ecm main relay is it inside the computer or is it another computer. as it looks like a need to connect two power wires to it
and then change the disy over and hopfully should go.
