I'm swapping an H22A into my 92 accord EX. I've got a couple of questions that i've never noticed coming up before, thanks in advance.
Has anyone else swapped to a manual tensioner in there H22? If so, did you have any problems with the clearance between the timing belt tensioner and the balancer belt tensioner? My thoughts right now, are just to use extra washers, but i was wondering if that would have any adverse effects....
also, on the vacuum line that goes from the FPR to the IM, there's an extra senser, that wasn't on the accord. Does anyone know if it's alright to just bypass the sensor and run the vacuum line straight to the IM?
Thanks for any help.
-Darin
-Darin
