H22a Oil Help
h22hizzie
Okay so I did the h22a swap into my eg and it will not stop throwing code 22. when i clear the battery it will stop throwing it the first time around and then it will throw it again the second time around... (if that makes sense) . I have checked my wiring a bunch of times and had my good friend thats done this swap before check it also. I have changed my VOPS and still doing it. I am wondering if it is because I am using 10W-30 should I be Using 5W-30 in AZ???
Its not the oil. I can tell you that. You might check grounds to start with. Then maybe you have a plug switched? Thats what mine did.......
