alterdcreations
Member
ALL PICK RESIZED. ENJOY
i am in the process of building a h22a4 short block.
i am looking to rebuild with factory usdm parts.
stock rods and pistons. will use coated main and rod bearings.
also will use apr custom rod bolts.
it motor will live in high rpms(i like to rev) oil pump will be changed for a higher flowing unit.
my question is will i start spinnig bearing or breaking rods?
what is a safe rpm for a stock unmodified bottom end and any ideas on my set up?
thank you
thank you
