H22a swap bogs
Discussion in 'HYBRID -> BA-BB /CA-CD' started by 92vegaslude, Mar 26, 2004.
  1. 92vegaslude
    92vegaslude Junior Member
    Well my 92 si with 94 H22a swap p13 ecu is bogging every now and then. Usually when it is warming it does it around 3k, it just hesitates for a second then gets moving. Also when warmed up around 3k it does the same, but not in all gears, usually in 4th or 5th it hesitates when warm.
    Can anyone help me. Or give me some ideas on what to try first, to rule out others.
    thanks for the help.
    Mike
  2. sleepn_accord
    sleepn_accord Senior Member
    first and foremost check your ignition timing.
    It may be your distributor crapping out.
    I had the same problem.. turned out my distributor was going to hell.
    I sense that it is probably ..well ignition timing.
  3. 92vegaslude
    thanks for the quick reply I will check that out tonight. I was planning on doing a tune up next week sometime.
    Thanks again.
    Mike
