1998typesh
Hey guys, I've finally completed my h22a swap into my 98 sh. I also swapped in a M2B4 trans. It also has an OBD1 ecu (chipped p28) and conversion harness. I swapped over the crank and timing sprockets, along with the oil pump and tdc/cps sensors. I installed the obd2 dizzy/intake manifold/fuel-rail and injectors and t-stat housing from the h22a4 and checked the grounds (trans/thermostat housing/valve cover). I also checked the coil and it tests fine. Because it was sitting for years, I drained the gas and put in 5 gal of 93octane.
It cranks over but will not start.
Any Ideas?
Any Ideas?
