h22a swap problems
instantnoodles
i finally got my distributor wired correctly.... my check engine light is on blinking code 14 (IAC - idle air control valve), 22 (VTEC pressure valve), 41(Primary oxygen sensor heater) my problem with the swap is im only catching fire on cyclinder 4 & 3.... 1 & 2 not sparking not sure what the problem is i had some 1 test my injectors its good... did a wet & dry compression test its good...i didn't test out the distributor but wouldn't it be good since 4 & 3 is sparking.does ne1 think its my motor thats bad??? because i paid good money for it and shop is closed down can't get my $ back
HELP A BROTHER UP!!!!!! :)
does anyone else eat ramon noodles raw? im to lazy to cook them so i just open it up and break it up and dip it into the lil bag o flaver
