H22a swap to 1994 civic ex coupe help
Discussion in 'Wheels / Suspension / Tires / Brakes' started by kingcoupeH22, Sep 17, 2015.
  1. kingcoupeH22
    kingcoupeH22 New Member
    what up peoples i finally have gat my H22 swap done. and boy is it up and running strong but now i have no idea about what suspension and brake uprgrades i can do that wont brake the bank i would like to use used parts for brakes what will fit? and for suspension i need badly but dont have much funds at this moment ine time please any input is appreciated.
  2. Briansol
    What chassis are you working with?
  3. Briansol
    nevermind- reading the title helps :X
  4. Briansol
    Popular choices are simply to go with brembo blank rotors and a good set of street/strip pads like stop tech or hawks hps. put some good DOT4 fluid in there and you'll have a lot of braking power.
    suspension, to do it right costs a bit. If you can't afford a good setup, don't waste money on junk to hold you over... save up a bit
