H22a swap
Discussion in 'HYBRID -> BA-BB /CA-CD' started by hondacivicjosh, Dec 19, 2003.
  1. hondacivicjosh
    hondacivicjosh Member
    Roanoke, Va
    its a 91 honda accord can i use the same motor mounts or do i need different ones. of course i would replace the same ones but i want to make sure i need different ones
    thanks
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    I used the same ones that were stock, and I have automatic. I think the manual models had to frankenstein one mount. Do a search if you're going manual.
  3. 90h22accord
    90h22accord Junior Member
    i recently did a h22a swap into my 1990 manual tranny honda accord and all the mounts are good except on one side you have to tap (tread) an extra hole so you can put a bolt in there.
