Me and My brother is planning to swap an obd1 H22a into his 95 accord ex. What can we keep off the f22 motor. I know that some wires need to be extended. Is there anything else?
If u don't have axles u can use the ones from your accord, makes sure u use the midshaft in your h22. You can use powersteering pump if u are keeping that. Alot of it is just getting your motor in and then seeing what is left. Then see what you can use and if u have anymore questions about finding or wanting to know something just ask on here, it is a great site.
Everything I have read is that if you use the stock axels from your car, then you also have to use the half shaft off your original motor. They are a set of three that must stay together.
