H22a swap
1badprelude66
Mustang Eater
hey guys i have a question, i have an 1994 h23 prelude and i want to do a h22 swap. Will that be a clean swap or will there have to be modification needed, and if so what mods.
The engine will bolt directly into your car.. just make sure you get an OBD1 engine. The only thing you will need to modify is you'll need to run the wires for the VTEC components and the IAB solenoid on the intake manifold to your ECU. All the information to do that is available in the reference section on this site. Look for 'How to wire VTEC' and the 'ECU Pinouts' articles and you should find what you need.
