h22a tranny swap
accordex98
wutz up guys i wuna put a h22a trans in my 98 accord along with a act clutch would this be 2 good step
when you do switch the 5th gear from you F23 tranny to prevent high RPMs in 5th gear.
I don't think that's really necessary. The H22 transmission isn't geared quite as high as the B16 or Type R transmissions. He should still get decent gas mileage with the H22 fifth...
ohhh ok now when i do da swap ima also put a clutch in as well just 4 alil more bite but should i order a clutch 4 a prelude or an accord
im pretty sure the h and f series are all the same, with the exeption of the s2000 motor of course... i bought my stage one clutch for my f22 tranny and now that im goin to put in either an h22 or h23 it will fit in that as well, i also looked at a couple places onl;ine and they are the same part n umber... same with the f23...
