Nobody really uses this motor because this is a very difficult swap to do because of the atts system that this motor has. The best thing for you to do is to get a complete swap and buy the Type S pistons and cams and put in that motor. Really this is a cheaper option and you will have the same hp as a H22a Type S and possible to pull a little more power with a good tune. I have a 94 Accord coupe with an H22a in it and when the funds get right I am planning to buy type s cams and pistons as well. Those motors are running at least 4,000. Buying the base and putting the cams and pistons is the best thing to do all around and much less of a headache.
