h22a type s swap m2u4(atts) accord type r
boaz
I just bought h22a from type s prelude the model with m2u4 transmission (atts) and it doesn't fit at all. The axle shaft is connected from another place and the ecu is with out th atts connection.
I have the h22 type s ecu and the atts ecu do you think that if I will buy the axle shaft it would fit ? any suggestion would be welcome
I would suggest not using that transmission and just buying a regular manual gearbox to go with the motor. People generally don't try to swap those particular engine/tranny combinations because it's hard to make them work right in anything other then the vehicle they were originally installed in...
axle shaft and crank senssor
I have regular transmission but the axle shaft connect to the engine is in a different place and I didn't find any crank sensor on the sh model
