NyQuiL_AcCoRD
Member
What's up Hondaswap peoplez? Currently, I'm planning to go turbo on my H22A. I know the JDM H22A block is an open-deck, and a H23A is a slightly close-deck, which allows for higher boost. Also, the H23A is a 2.3 liter, and the H22A is a 2.2 liter. So, this is my plan:
If - H23A Block: I plan to go with a sleeve block, new low-compression pistons, rods, crank, balancing/polish, bearings, pumps, and seals. Since the H23A block is a 2.3, it has a slightly bigger displacement, but will I see a bigger gain in power verses a H22A block with the same build, but only with a 2.2 liter?
So, which block will be a better build; H22A or H23A block?
