H22a VTEC head, on H23 bottom end
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Uppertorso, Mar 26, 2004.
  1. Uppertorso
    Uppertorso Senior Member
    Winnipeg, Manitoba
    Is there anything special that needs to be done to make this work. Is it similar to an LS/VTEC job. If anyone has information it would be greatly appreciated.
    Thanks
  2. sleepn_accord
    sleepn_accord Senior Member
    It's not worth it unless you're going to build the motor completely up. I've had a stock H23A and it's only slightly more torquerier than the h22a..but not even enough to be that noticeable.
    But there is a writeup somewhere on the net.. I'll try and find it.
  3. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    not worth it!!! buy an h22 instead, i mean stuff adds up quick you need the h22 head, a vtec ecu, h22 oil and water pumps, you should use the little oil squirters...this has been asked a few times search around and see the details
  4. tab
    tab Super Moderator
    Aberdeen, Washington State
    Information is pinned in this section.
  5. Uppertorso
    Winnipeg, Manitoba
    I appologize if my question wasn't clear enough. A good friend of mine purchased a H22, and the bottom end is blown out of it. But we do have access to a H23 bottom end. I need to know what modifications need to be made to make this setup function. Do we have to run oil pressure to the head like on an LS/VTEC swap??? Any input would be appreciated. :D
    I am not asking if it is a good idea for more power, i need to know what modifications I need to do to make it work.
    Thanks in advance.
  6. tab
    tab Super Moderator
