h22a whp
Discussion in 'Engine Building' started by goldrims, Feb 22, 2009.
  1. goldrims
    goldrims New Member
    hey i just got my h22a in, just wanted to know what the easiest way off making 200 whp from my h22a, i/e/h etc.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    nos
  3. George777
    George777 ^^ Likes Bewbies
    With your mom
    There really isn't such a thing as "easy" power. Bolt-ons can get you closer, though.
  4. goldrims
    goldrims New Member
    ok then put it this way, Any guys out there running 200+ whp on there h22, can you let me know your mods.. thanks
  5. Briansol
    i/h/e ,cams, valvesprings to hold it, and a tune should put you real close.
  6. Makahana187
    Makahana187 New Member
    word^^...isn't the h22 close to 200hp stock any way?
  7. Briansol
    yes, but the drivetrains eats up about ~40hp or so
  8. hondarin
    Texas; where else?
    and lightweight clutch, flywheel, and wheels.
  9. MthaFuknGreen
    Lodi, CA
    get the h22a type s or euro r.
  10. BrutalB83
    Rochester Hills, MI
    Crank horsepower doesn't equal wheel horsepower. At the wheels, a stock H22 is going to put down around 150-160 horses...
    Please tell me how any of those things add horsepower...
  11. MthaFuknGreen
    Lodi, CA
    some people consider freeing power up, adds horsepower.
    if thats the case, strip the interior.
  12. George777
    With your mom
    That does nothing for adding horsepower. All that helps is the weight aspect of it.
    If your car has 150hp and you take 300lbs of stuff out of the car, it still only has 150hp.
  13. BrutalB83
    Rochester Hills, MI
    I call those people "idiots"...
    :werd:
  14. MthaFuknGreen
    Lodi, CA
    i know..
  15. sevenhillsbilly
    sevenhillsbilly New Member
    but you do have to consider the power to weight ratios and such
  16. George777
    With your mom
    I'm aware of that. But I was pointing out the fact that it still doesn't add power. If you send the same car down the track two different times--one with interior, one without--the numbers aren't going to be spectacular enough to make someone want to gut their car.
  17. aimonb
    aimonb Been down so long...
    portland, OR
    Do what I did. Turbo it. I get 221HP & 220TQ @ just 6 PSI on a dynapack dyno. And this is with a cat on a 2.5" Apexi exhaust w/ a Hondata S300. Once I switch to 3" I will up boost to 8 PSI and most likely get another 20-30 HP :)
  18. goldrims
    goldrims New Member
    thanks for the response man, but more interested in N/A upgrades, not really into turbo for h22, this engine strikes me more as allmotor builder, leave turbos for b18b n gsr,:D
  19. plng777
    plng777 New Member
    Build up the bottom block, (darton M.I.D sleeeves it), stroker kit (better displacement), Stage 2 street cam/ gears, valve srpings and retainers, Larger exhaust system 2.5-3" piping.
    Vtec should scream like no other. Someone correct me if i'm wrong, this should make somewhere in the 230-240 neighborhood.
  20. Sungsu
    Sungsu New Member
    So it sounds like the H22A drivetrain eats up 25% of the power. So you would need to make like 260HP to the crank, to get 200 to the wheels. damn, our H22s SUCK! I thought FWD drivetrains were supposed to be more sufficient than RWDs? Also I thought the shorter gears of the H22A tranny (the m4....whatever) would make it more efficient, too.....I guess not.
