H22A
Status
Not open for further replies.
nsxracing
Please help me, I swap a h22a into a 92 Accord, and everything was done! The car runs weird, when I didn't put in the gear, I can rev up to 8,000rpm. But when I try to drive it, (put in 1st gear) the car can only drive 5-10mph (The rpm won't pass 2k, if I step on the gas, it just like nothing, won't move or anything.). 2nd gear the same, won't pass 5-10mph. The only way I can rev the rpm over 2,000 while sitting in gear is press down the clutch. Once I release the clutch, the car will not run again.... until it drop below 10mph. Please help me... what is my problem!!
This topic has been closed :locked:
Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
If you have any questions, please PM the moderator who closed this topic.
-The moderating Team
Please refer to our FAQ. There is no need to post your topic more than once.
This topic has been closed by a moderator. Please continue your question in the other thread that you started.
Thanks, Moderating Team
:locked:
Status
