h22a1 build
Discussion in 'Prelude' started by chadisaac, Mar 22, 2010.
  1. chadisaac
    chadisaac New Member
    anyone have list of recommended upgraded parts when building a stock h22a1. would like to stay all motor and not break the bank.
  2. TurboDave
    TurboDave New Member
    Eastern, CT
    You will break the bank on All motor depending on what power gains you want. If you go Forced Induction you get more horsepower for the buck.
  3. serrilion
    serrilion In my own little world! VIP
    Vermont
    ok well u can do LA sleaves to start if u want to boost it. Or you can invest in a brian Crower cam set ... $400 range for price.... could get some pistons and rods... I would look into the cams and pistons in what not... maybe a set of really good headers and a nice exauhst :p
  4. TurboDave
    Eastern, CT
    a set of headers? :eek: Plural on a 4 cyl. exhaust isnt logical. lol, sorry.
    And Golden Eagle Mfg in Cali does awesome reputable work on engine block sleeving. call them and tell them what you want and they can help lead you in the correct path. Boosted @ like 20 psi w/ 400whp can run you like 5g and double that if you want N/A. Golden Eagle Manufacturing^_^
  5. eatsleeprave
    eatsleeprave New Member
    My h22 build reciept.
    HONDA 2155 Dish $475.60
    Ring set $80.93
    Valve stem seals $20.80
    belt $23.35
    Install sleeves $1500.00
    Head gasket vtech $93.95
    Main Bearing set $47.72
    ACL HONDA race series rod set $68.20
    HONDA thrust washer set $7.73
    SKUNK2 Racing Camshafts $795.00
    Skunk2 Valve spring set $269.43
    And more i'm just tired of typing haha
    TOTAl is $5359.75
    274WHP
    476WHP after Turbo install on 19psi of boost
  6. serrilion
    Vermont
    Not a bad deal... what size turbo you running? should be around 516 crank HP if im not mistaken... got slip pic's? or motor pic's hehe
