h22a2 eg turbo
Discussion in 'ECU's, Electronics, and Tuning' started by tat, Jan 2, 2010.
  1. tat
    tat New Member
    aright guys ive got a 95 eg h22a2 and im rebuliding the engine and im planing on putting a turbo on it which ecu would be the best to use with this im going to put a skunk 2 cams, low comp pistons, con rods,dont now with the cylinder sleeve yet and skunk 2 inlet mailfold:)
  2. keg
    keg New Member
    chip your ecu
  3. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    Get it tuned properly when your setup is ready.
    I suggest the NepTune RTP as a highly configurable and easy to use tuning solution. You can also get tuned by a NepTune dealer if you don't want to do any of the tuning yourself.
    HRTuning - Home Of The NepTune RTP and TunerView, links are on the right hand side.
  4. tat
    tat New Member
    ecu chip
    what chip the p13 ye what type or what make
  5. HRTuning
    HRTuning New Member
    Phoenix, Arizona
    You'll want to get a P28 equivalent ECU to be able to get tuned properly, as the P13 doesn't have a public editor that supports boost tuning properly.
    You can get tuned on several platforms. NepTune, eCtune, Hondata, and Crome. I'd suggest finding a tuner and seeing what he uses or looking into each of these programs yourself and choosing one you like the most if you want to tune it yourself. Good luck!
