Probobly not the normal first post but hey here goes...
Basically me and a friend have brought an unfinnished progect involving putting a H22a2 engine in the rear of a peugeot 106 making it RWD.
We have the completed the bodywork and are now attempting to sort out what the prevoius owners has done with the engine!
The problems are as follows.
Also is there any way of wiring up a light to the ecu to access any error codes that may been stored. Obviously the front part of the loom is no longer there to access this!! If this is possible does anybody know what wires would need to be connected together.
The serial number for the engine is 2800153 H22A2 if that helps.
Any ides would be most welcome.
- The idle will not settle it hunts from like 1-2k rpm. I have read on this site that people need to chech and clean the fast idle valve and the ICV but i dont know exactly which ones these are. Does anybody have a picture or write up of what to do here?
- Secondly the VTEC will not engage. We have tried all the usual things like the solenoid wireing and the oil level/temp but to no avail. We think the problem may be when the prevoius owner installed the engine he cut alot of the wireing loom away. All we have left now as you can just about see in the photo is 1 red plug left I dont know if this is any use or not!
