H22a4 cold stall.
JeremyGTS
Hey I have a 4th gen swapped with a h22a4 and it stalls when cold untill it reaches normal temp... ive cleaned IACV, running a p72 "skunk2 chipped"
ive had the ALT tested and the battery tested and they seem fine..? could this be caused by a bad ground bcasue the ground coming from my head to the frame looks coroded... aslo its hard to start i have to press the gas other wise it sounds like it wants to start up, cranks then just putters till i give it a tap of throttle...
any help would be great.
Clean up that ground reguardless. Did you check the IACV for function? Clean and broken doesn't do you any good.
good point. ill check for function. and replace if i have to.
good news is im getting my ECU tunned propperly to get that skunk2 mess outta there.
