first i did do a search!
Hi just purchased a 92 Prelude Si with a swapped H22a4. I was just wondering how to tell if im running the right fuel injectors... i have to press the gas to start the car and it will stall untill it reaches normal temp. I noticed that the 92 had the fuel injector resistor box but when i got the car there wasnt a resistor box hooked up.
Is this a problem i know the 5th gen had the saturated injectors and the 92 was peak n hold... is there any test or any kind of writing on the injector i could look for to make sure i am running the saturated injectors?
sorry i am a total newb this is my first honda and first swapped car and im trying to learn as much as i can.
i have no idea if the car is OBD1 or 2 but i have pulled codes from the CEL before by jumping the connector and getting the flashing light. (NOT GETTING CODES NOW) I have no idea what ECU im running in the car... is there any markings that might be able to help?
