H23/22
Homer Pimpson
About to swap a H23 into my 5th gen Accord and I was wondering how similiar the H23 swap is to an H22 swap into an Accord. I am very familiar with the H22 swap, but I haven't heard much on the H23 into the accord. Will I encounter the same problems the H22 swap into the accord has?
Thanks for the info Tab, I know you are the main authority around here when it comes to the H22 swap. I also had a question about the ECU, will I just be able to pull my F22 ECU and plug my H23 ECU in place of it? No wire problems? BTW: Just to let you know, I'll be using a USDM motor.
You'll have to wire a knock sensor, and the IAB, and make some engine harness modifications. All the usual stuff. The computer will plug in the same. You'll also have to switch pins A6 and A11. There is a lot of info on this site, so search a bit.
