h23 ek swap
rocky2018
I have a h23 swapped ek and am having distributor problems the car will only start and run when i turn the dist completley off kelter way beyond putting a bolt in it ive timed and retimed but it will not run bolted in place im using my stock harness with a d16 dist complete internals bolted down in a h23 dist housing any suggestions
or just get the correct dist
Since I had to build it there isn't a 'correct' dist but I got it I put the civic shaft in when I needed the h23 the holes on the end where it sits in the Cam is what was 180 off
I think he was more saying a rewired H23 Distributor might serve you better.
