H23 head swap.
Discussion in 'Engine Building' started by ihatemyprelude, Jul 27, 2008.
  1. ihatemyprelude
    ihatemyprelude New Member
    Ocala, FL
    since this isnt a popular block on your fourms...
    H23 head swap. what is the best head to bolt on a H23 ( non vtec swap )
  2. efboostin
    efboostin New Member
    h22 head
  3. kebo09
    kebo09 New Member
    St.thomas u.s.v.i.
    I have a fully build h22 head to block with high compression piston.I have skunk2 stage 2 cams in.What is the best cam setting for this set up.
  4. Korbel_Express
    Korbel_Express New Member
    Waynesboro, VA
    I would start with Intake 1 degree retarded, and the Exhaust 2 degrees advanced. I find this overlap gives nice midrange power without losing too much on the top or bottom. The higher you want it to make the power, the more I would take that setup and retard the cams. This is just a starting point of course, and be sure to check your timing after every change.
