H23 V-tec Specs?
Discussion in 'Engine Building' started by sr20b20lsvtec, Mar 5, 2005.
  1. sr20b20lsvtec
    sr20b20lsvtec Junior Member
    ok now I know that it is possible to do an h22 head swap on a h23. what is the hp gain of the head swap? is it more powerful then a stock h22? What about using type-s piston's in the h23 wil that work? will there be more power
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    The OEM H23A vtec is rated at 200PS, so it's probably going to be in the same neighborhood.
  3. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    There's no such thing as an "OEM H23A vtec"... But anyway. My guess with an H23 bottom end and Vtec (H22) head, would be around 210-215 hp to the flywheel.
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Wrong. :)
  5. xj0hnx
    C.C.TX.
    Just because you don't know about it in your little world, doesn't mean that Honda didn't produce it for about two years in the Accord wagon SiR in the real world.
  6. baker423
    baker423 Senior Member
    Upstate New York, 14882
    OW3NED :lol:
  7. brian11to1
    brian11to1 Senior Member
    Not to mention your car is not a real SiRII. Was it shipped from Japan?
  8. reckedracing
    reckedracing TTIWWOP VIP
    NY
    :unsure: :ufucktard: :owned: :tisk: :kick: :blah:
  9. 2pacolips
    2pacolips New Member
    have a h23a that did lick bearings n the inside crab up, took it out n have in a f22b, but the h way better how much would it cost me 2 get a vtech head n put it on the h23a, knowing it ave to go machine shop. is it even worth it. or is it better to combine both engines i have or just modify the f22b. natural aspirated
  10. nootrac22
    exeter pa
    the best thing to do in that case is to check the date and not bring threads back after 4+ years
  11. Kovec87
    Kovec87 New Member
    Hello everybody, so i have a '88 Honda Prelude Si 4ws with a b20a5 engine, the object i propose to myself rebuilt this car, and i need more horsepower in the future, so my question is which type vtec honda cylinder head compatible this engine ?
  12. MrEck072
    MrEck072 New Member
    Specs om H23a Vtec (blue top) found on wiki
    H23A VTEC
    In 1998 Honda produced a rare VTEC version of the H23 engine for use in Japan only. It is essentially an H23 block with an H22 head. The power is on par with a typical H22 engine, but with a lower redline. It does, however, have a few more foot-pounds of torque than the H22.
    Specifications
    • Bore × Stroke: 87.0 mm × 95.0 mm (3.43 in × 3.74 in)
    • Displacement: 2,258 cc (137.8 cu in)
    • Valve Configuration: DOHC, 16 valves, VTEC
    • Type: In-line 4 cylinder, aluminum block and head
    • Compression ratio: 10.6:1
    • Max output : 200 PS (197 hp/147 kW) @ 6800 rpm
    • Max torque : 163 ft·lbf (221 N·m) @ 5300 rpm
    • Redline: 7000 rpm
    H23A VTEC
    • Found in the Japanese 1998-2002 Accord Wagon SiR (CH9). It produces 200 PS (197 hp/147 kW) & 163 ft·lbf (221 N·m) and comes with a "blue top".
    • Found in the Japanese 1998-2002 Accord Wagon AWD (CL2). It produces 200 PS (197 hp/147 kW) & 163 ft·lbf (221 N·m) and comes with a "blue top".
  13. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    this thread is old as shit
  14. BrutalB83
    Rochester Hills, MI
    The answer is that there are no VTEC heads that will bolt to that block. Absolutely none. So have fun with it. And as others mentioned, next time, check the date on the thread before you post...
