h23 v-tech?
Discussion in 'Prelude' started by HondaElite, May 30, 2007.
  1. HondaElite
    HondaElite senior member
    fall river.mass
    i was wondering what i would need and i heard something about a cooling problem they had with it..and i had a question on what hatch would be easier to swap it into...i was thinking ek...anything helps thanks
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    ek is right ,, but its vtec
  3. HondaElite
    fall river.mass
    yea h23 vtech 2.2 head on 2.3 block
  4. AHHVTEC
    Alabama
    thats vtec
  5. HondaElite
    fall river.mass
    dam right...=]..but is converting a h23 to a h23 v-tech worth it?
  6. AHHVTEC
    Alabama
    sure as long as its at least 900mhz
  7. HondaElite
    fall river.mass
  8. BrutalB83
    Rochester Hills, MI
    It's not "V-Tech," it's "VTEC." V-Tech makes phones, hence the 900 mhz comment. He was messing with you.
    Anyways, if you're wanting a motor to put into a Civic, then I'd consider a B-series before an H-series. H-series into a Civic isn't a bolt in job. It's really tight in the engine bay, plus you have to cut into the Civic's transmission tunnel to get the shifter up through.
    A B-series would be a much easier swap. You can do a hybrid build on those too; if you're looking for something torquey I'd suggest a B20 bottom end with a B16 or B18C head.
  9. spoolinb16si
    spoolinb16si New Member
    WVA
  10. boostedf22
    boostedf22 dis is why im not
    in the land of OZ
    X2..... I needed that laugh tonight.
