h2b swap is super slow!!!!
coreyg
so i finshed my h2b yesterday and is slow as dog turds. its throwing a tps code. could a bad tps cause any huge power loss??
tps will cause a big loss because the ecu doesn't know how much throttle you are giving it
make sure you hae continuity between the correct wires at the ecu and the tps itself, if you cant find continuity there then check and make sure you didn't plug the map plug into the tps and vise versa.
well the multi meter reads 0 at closed throttle and 1.56 at wot... its getting the 5v through the yellow wire and the ground is good...what the ef is up here?
remove your intake tube and check and see if the throttle plate actually opening all the way, if not there may be a problem with the cable/linkage, if it is opening all the way then the tps is bad.
BTW you are checking the voltage with the engine Off i assume.
