ok well heres the thing i know u need the h2b kit, and the mounts u dont use h series mounts in order for the motor and tranny to sit in the right place u need to use b series mounts. i also know that u need to shave a piece of the block for the axles to fit correctly, and the subframe need to be moded for clearance for the pulleys. and i heard somthing else about needing a bracket to put a single cam alternator on the h series block.
