hahaha... local guy
Discussion in 'Auto Multi-Media' started by eg6sir, Sep 28, 2008.
  1. eg6sir
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    WTF plastic? o_O
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    newer toyotas run platic manifolds as well...but that one was FUCKED
  4. BrutalB83
    Rochester Hills, MI
    I believe the D17 has a plastic intake manifold as well...
  5. Civichatch9one
    Civichatch9one New Member
    beat me to it^ but yea the d17 and i thing the r18 and some other new hondas
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    Yup. Automakers cutting corners wherever the hell they can. Honda jumped on the bus.
    Old man honda is rolling over in his grave.
  7. Civichatch9one
    and aftermarket i/m's especially for the d17 can reach around 1,400s at least they have an option to get rid of that dumb top mount tho.
  8. BrutalB83
    Rochester Hills, MI
    Has anybody tried using a Y8 manifold on the D17 engines? Seems like that might be a decent and cheap alternative to after-market, assuming that you could easily make it work of course...
  9. Civichatch9one
    yea some people do. *edit* it takes custom fab work to get it to work. but its an option. but people pushing big numbers on the d17 turbos use an aftermarket i.m from jdm fabtec. but like i said its costly.
  10. hosmer
    B R I D G E W A T E R
    GM's been using plastic intake manifolds since the mid 90's
    they've always been POS's
  11. NissanNiNjA2nd
    NissanNiNjA2nd Senior Member
    The reason that happens in the same reason it happens in 302 intake manis
    they are extremely bad at puddling the Nitrous into certain pockets and then it gets hot....... BOOM.
    Direct port ftw.
  12. GlassHeadlights
    Calgary, AB
    Newer Mazdas use them too, at least I know the 3 does.
  13. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Im glad ive got an older honda. Despite all that plastic, new cars are much heavier too.
  14. GlassHeadlights
    Calgary, AB
    I'm starting to question some of the newer Hondas too. I've seen Civics in the autowecker with 400,000-500,000 kms on them and the Odysseys couldn't get 80,000 out of a transmission.
  15. Civichatch9one
    older hondas are where its at. i beat the shit out of my d15 when i wanted to swap it. and it wouldnt die. i had a 02 civic dd and gave it gas every now and again but never beat on it. and at 60k i spun a bearing. they dont make em like they used to.
  16. Justin66
    Make em last gentlemen!
    ...and a few ladies.
  17. 150
    150 New Member
    150
    What can i say....local is lekker.
  18. eg6sir
  19. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    A lot of the 96 and up Hondas have the most issues. I know the 96-00 D16Y's having issues with oiling, thus you see a whole bunch of them with spun bearings or thrown rods.
  20. budda
    budda New Member
    Cincinnati
    I just don't see why they would run nitrous on a plastic manifold. They're just asking for trouble.
