well, i've got my hatch ripped down getting the turbo setup together
but i need some tips on the radiator...
wow, thats a lot of hacking huh?well i dont have the pictures anymore or the car, but what did was make a notch in the crossmember for the rad. and had to notch the hood for the rad cap.
not really. just a notch on the crossmember about 3 in" long, and hood just have to notch the under side. I have to get pictures of it from the kid i sold it toQuoted post[/post]]
i'd be satisfied with how your setup looksI think one of the feet lined up, and I drilled a hole in the subframe for the other radiator mounting foot thingie (the one towards the driver's side) and ziptied it to the subframe...it sat a little bit tall, but nothing some minor dremeling couldn't fix. Didn't rattle around at all. I believe you can use a 95 Dodge Neon radiator and it'll mount up just like a 92-00 radiator, except it's a few inches shorter and will clear the hood with no modification. The reason I bootlegged mine like that was my fullsize EF radiator took a shit on dyno morning, and I needed a quick fix.
Quoted post[/post]]
I just read a project thread over on H-T....*rumage rumage*....
HERE it is.
Scroll down and you'll see what he did.. it looks a LOT better than civicious's "Gangsta-ass bracket"...
He just cut out a little bit of the front crossmember and voila.
-Andrew
Quoted post[/post]]
Not to thread jack, but I'm thinking about hacking up my radiator(don't worry, I have a backup); I want to cut out some of the core around the side but leave the top and bottom "covers" on so it would sit like stock. This is for a "ram air" system btw. Would simply JB welding aluminum sheet over the area that was cut be able to hold back the pressure?
Quoted post[/post]]
Quoted post[/post]]
Not to hate,
But that would be a pretty stupid and ricey thing to do.
It would be easier to just buy a 1/2 sizer and be done with it. ?
