Hamby's Turbo D15Z1
Discussion in 'Civic and del Sol - EG and EK' started by hondacivicdx92, Jul 2, 2008.
  1. hondacivicdx92
    hondacivicdx92 Hamby
    Indiana
    Ok, so i posted a thread ( http://hondaswap.com/civic-del-sol-eg-ek/out-b-back-goes-d-129746/ ) about my swapping back from the B18B1 to my D15Z1. Now for those who are thinking the same thing I would be if I just read this, why the hell would he do that, well if you read my other thread you will know why. Anyway, the motor is back in, the turbo is done, and it's boosted. Now I am only running 5 to 6 PSI for now but eventually I am going to build a D16Z6 and will be able to run a lot more boost. It now has a T3/T4 turbo, 2.5 " downpipe, knock-off BLOV, adjustable fuel pressure regulator, and a front mount. Here are a few pics of my ride. Feel free to leave comments and suggestions.
    [​IMG] [​IMG] [​IMG]
  2. mintoxik
    mintoxik Member
    Oceanside
    very shiniy intercooler i like it
  3. efhondakid
    Akron-Canton, Ohio
    Get rid of the Altezzas, other than that it looks pretty good.
  4. BrutalB83
    Rochester Hills, MI
    So what are you using for tuning? Oh, right...never mind...it's not necessary, right?
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Cooooool. Any dyno on the Z1?
  6. Bkkfarang
    Bkkfarang New Member
    Bangkok and Shenzhen
    is it just me or is the waste gate dumping on to the air filter ? oh and i agree with efhondakid get rid of the Altezzas, also what bumper will you run ?
  7. hondacivicdx92
    Indiana
    For your info brutal, I did have it tuned, and I never said that you don't need to have it tuned because that would be false. All I said previously is that engine management is not necessary.
    No dyno yet, I won't be able to get it on a dyno till I go back this semester.
    The wastegate is not dumping into the filter, it dumps right next to the filter but it will have a dump tube soon. have to get a flange and I am going to be running stock bumpers( yes the ic piping will have to be changed slightly).
  8. awptickes
    MD
    What RPM does the t3 begin to make boost at? Peak boost? What are the trims?
  9. BrutalB83
    Rochester Hills, MI
    Are you talking about tuning with an FMU then?
  10. hondacivicdx92
    Indiana
    basically. you can fool you stock ecu by using a "missing link", retarding the timing, and turning up you fuel pressure by either using an AFPR or using an FMU. By doing this, you can safely run 5 to 6 psi.
  11. robertbergl
    robertbergl New Member
    Georgia
    Nice! Other than the altezzas that is the same thing I want to do with my Y8.
  12. jinji85
    jinji85 New Member
    hi my english too bad. i have d15z1 turbo .use ecu p1j chipped converted to vtec evreting is good.
    i need bin setup ?and fuel compesation timming ign
  13. PhyRe
    PhyRe Senior Member
    ct
    dont need to read y u did it i know d > b. and as for "safely" running a fmu i dunno bout that. it will work but u cant romp on it u cant dyno it safely to many uncertainties. but looks good n good luck. keep the ricer lights its that "sleeper" look
