handling question
Discussion in 'Wheels / Suspension / Tires / Brakes' started by sporkhey, Aug 12, 2009.
  1. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    98 civic, lowered with not sure what springs (green in color). I bought the car lowered and it seems like the handling is so damn touchy. Driving on the interstate and you barely touch the wheel and its swaying all over the place. If you let the wheel go it tracks nice and straight. Rides good except for the touchy touchy steering. Any ideas why? Or is honda steering just really sensitive or does the lowering have something to do with it? Any parts to help? links please?
  2. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    It might have fucked with your tow and camber angle. Take it to a shop and get it alind.
  3. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    The lowering changes the suspension geometry a little bit which in conjunction with the stiffer feel make the handling seem more sensitive. Like matt said though it's possible that whoever put the springs on didn't have the car aligned, so I'd do that before your tires blow up.
  4. E_SolSi
    sounds like you are toed out in the front
    get it aligned
  5. caboose
    caboose USDM to the bone
    Hamilton, MI
    +1
  6. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    I can let the steering wheel go and its fine, straight as an arrow. And the tires dont seem to be worn on one side more than another. I have driven a car that has been out of align. Thats not what this is. Its just super touchy.
  7. OGMatt
    vic B.C. Japanada
    Time for a 600mm steering wheel then. LOL
  8. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
  9. caboose
    Hamilton, MI
    just because the car goes straight down the road and doesn't veer off when you let go of the wheel doen't mean that your toe is set correctly.
    for ghits and siggles take a tape measure and measure the toe.
    also, what size tires do you have on the front?
  10. 95b16coupe
    95b16coupe New Member
    ct
    you are missing the point. there are 3 parts to an alignment, you only understand 1 part of it.
    there is caster, camber, and toe.
    if you come on a forum, and ask a question, and 5 people tell you the same answer, don't assume they are wrong if you don't know what is right.
  11. E_SolSi
    you are absolutely correct. its not your alignment at all
    in fact everything about your alignment is perfectly in spec
    your car simply has "touchy" handling and there is nothing that can be done about it
    of course you already knew this before posting here... so i guess the joke is on us
    good one!! :thumbsup:
    now i could go into detail on how to go about performing a string box alignment on your own, and how to dial certain handling characteristics in or out to get it to perform exactly how you want... but you probably already know how to do that too... so i wont waste my time
    thanks again for wasting our time... have a nice day... good luck with the "touchy" steering
  12. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    You guys are dicks - plain and simple. I guess this site you cant ask questions and give feed back. If im wrong about something then im wrong but being a dick isnt gonna help.
  13. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    I measured the toe, i measured 60 13/16 in the front of the tire and 60 1/2 in the rear of the tire. For a difference of 5/16. so that would be my toe? 5/16 out?
  14. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    ^^ as for tire size, 195/60/14. All the way around
  15. 95b16coupe
    ct
    it's not about being a dick. the problem is you. you asked us a question and we told you the answer. you just don't like our answer and proceeded to argue.
    the problem you described sounds like an alignment issue OR it could be your tires. we will give you ideas, it's your job to check them.
  16. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    ok so anyone wanna answer me about my toe. I measured it. does front and back have to be the same? is 5/16 difference something to be worried about? Anything else i can check
  17. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    How did you measure toe?I would get it put on an alignment rack and have it checked.
  18. caboose
    Hamilton, MI
    Sounds like you might be toed out... quite a bit too. Try getting it aligned and see what that does.
  19. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    Roger, seems like everyone says the same. Sorry for being hard headed. Will do.
    Also i saw some parts for camber for the front end. Would i need those so they can adjust it? Or are the oem parts on the car adjustable enough?
  20. sporkhey
    sporkhey New Member
    Gainesville FLORIDA
    I took a measurement from the front of the wheel and then from the same point on the back of the wheel- two measurement and got a difference of 5/16 of an inch.
