i swapped this in a long time ago and its been running great ever since. when i first finished the swap i noticed the cluch pedal was really hard, and i snapped about 5 pins in the clutch cable. in order to get the stock clutch cable to work i had to jack up my car and then lower it onto some 2x4's so the cluch lever on the tranny would give me enough room to slide the too short stock clutch cable into the lever. has this happened to anyone else? did the 90-91 integra clutch cable fix the hard pedal? if its not this then what may be causing the problem?
