Harness
Discussion in 'HYBRID -> EG-EK / DC' started by APEXi, Jul 12, 2005.
  1. APEXi
    APEXi Senior Member
    hey guys i've been havin a looking at my b18 harness ready for the swap and i've noticed there is no plugs on the harness that will plug up to the plugs on the heft side of the engine harness <_<
    wot i mean is this.... this is the harness layed out infront of my car....
    as u can see there is nothing on the drivers side to go to the plugs on the left of the engine harness..
    so this is basicly wot it'll be like 1's the harness is fitted.... the red line is the harness
    so wot im tryin to say here is, have i got the full harness? or do i have to use the driver side of the harness wich is already on the car? e.g.. drivers side door and plugs that match up with the plugs on the drivers side of the engine harness?
    i hope u understand wot im tryin to say here lol. its a right hand drive aswell jus so u kno and im gonna be swappin a b18 in
    thanx :)
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Try taking a picture of teh harness with a background that will actually let us see the plugs instead of a bunch of rocks.
  3. APEXi
    APEXi Senior Member
    ok here is the harness....
    and here r the plugs labled on the first pic...
    1.
    This r oviously for under the drivers side dash....?
    2.
    dunno wot this r for but there defo not gonna plug into the engine harness
    3.
    this r for the passenger door and ecu ect..
    4.
    these r for the fuse box and passanger side engine harness plugs...?
    5.
    this r for the passanger side lights ect..?
    hope this helps, there dont seem to be any plugs for the driver side plugs on the engine harness tho <_<
  4. xj0hnx
    C.C.TX.
    Is that an OBD II harness? That's not a complete anything.
  5. APEXi
    APEXi Senior Member
    yea its a OBD II harness
  6. xj0hnx
    C.C.TX.
    Well, that explains why it doesn't even come close to matching up to your OBD I car. What car is it from? OBD I/II Integras use practially the same harness as a OBD I Civic.
  7. APEXi
    APEXi Senior Member
    its from a uk spec 1.8 vti civic wich is not a eg or ek chassis its a M summink... its not ur average civic put it that way
  8. xj0hnx
    C.C.TX.
    I know what it is, I live in Germany :) my friend has one. B18C3 y0. Unfortunely, I have found a lot of problems with compatibility here in Europe as far as conventio0nal knowledge of Hondas, and their interchangability as known in the US.
  9. APEXi
    APEXi Senior Member
    thats cool, over here we have the b18c4's
    so wot the deal with the harness then?
  10. xj0hnx
    C.C.TX.
    It looks like it is still in teh same family as the OBD II CIvcs in the states, not the Integra, even though the Integra in teh states comes with that motor, and not a Civic. Ghey huh?
  11. xj0hnx
    C.C.TX.
    A solution would be..replug you harness, and run all the nescessary wires, get a US GSR harness, or a EDM ITR harness, and wire in the IAB manually.
  12. APEXi
    APEXi Senior Member
    yea just a bit lol, wot u recomend i do then? is there any chance i can get this harness in my eg and run the motor or am i gonna have to get hold of a eg vti harness?
  13. APEXi
    APEXi Senior Member
    dont forget that the eg4's and eg3's over in the uk r OBD0 lol thats another ghay thing lol
    when u say EDM ITR harness do u mean a uk itr?, would a OBD1 eg vti harness plug up corectly to the OBDII engine harness?
  14. xj0hnx
    C.C.TX.
    Ok, I had a brain fart, you guys are RHD, so a US harness would be backwards. an OBD I VTi harness, no, you'd have to replace some plugs. An ITR harness would be ideal for you.
  15. APEXi
    APEXi Senior Member
    a OBD1 itr harness yea? im gonna be running a OBD1 p72
    with the itr harness i'd have to wire in the secondary butterfly rite?
  16. E_SolSi
    a JDM GSR harness should be perfect
  17. xj0hnx
    C.C.TX.
    A 96+ one would be absolutely perfect.
  18. APEXi
    APEXi Senior Member
    a uk spec integra si harness would also be perfect rite?
  19. xj0hnx
    C.C.TX.
    You guys have Integra other than ITRs? Lucky, we only got the ITR here :(. Yes, it is the 1.8 DOHC vtec, just like the SiR-G correct?
  20. APEXi
    APEXi Senior Member
    yep, b18c1 i think <_< its a gsr motor anyhow :p lol
